It is currently Fri Aug 08, 2025 8:12 pm
PostPosted: Mon Jun 12, 2017 2:13 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
I've yet to build a dread (basing my plans on a '37 D-28) - I can do 00 and 000's all day long.
Am I crazy to think I might be able to squeeze a prewar dread side into 30" length if I bend them perfectly? By my quick measurement of the sides it looks like 30", leaving space at the tail for a wedge, might just work.
Or do I need to face reality and try to track down some orphaned 32' bees wing mahogany sides to bring this project to life?
PostPosted: Mon Jun 12, 2017 3:19 pm
Yeah just don't you dare make a mistake ;)
You may consider workign on an open work board just in case you need to fudge it and it won't fit in a mold.
These users thanked the author jfmckenna for the post: dpetrzelka (Mon Jun 12, 2017 3:24 pm)
PostPosted: Mon Jun 12, 2017 3:22 pm
Last Name: Kincheloe
Use a rectangular type heel so it covers more of the sides than a regular tapered heel.
PostPosted: Mon Jun 12, 2017 3:25 pm
First name: Daniel
State: Washington
Dread sides really are almost dead on 30" aren't they?
Sometimes a good challenge is all I need.
PostPosted: Mon Jun 12, 2017 3:56 pm
Sides don't actually need to meet at either end...
These users thanked the author meddlingfool for the post: dpetrzelka (Mon Jun 12, 2017 4:57 pm)
PostPosted: Mon Jun 12, 2017 6:31 pm
Last Name: Beaver
City: Lake Forest
I have never actually checked, but I would be very surprised if all Martin pre-war D's had the same specs.
As jfmckenna suggested, I would build with a work board. It will allow you to modify things if needed from your plan.
And what Ed says is so true. Just be sure the heel block and end graft cover up the short comings of those sides. (and don't forget to get the waist right where you need it before you bend)
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: dpetrzelka (Tue Jun 13, 2017 12:18 am)
PostPosted: Mon Jun 12, 2017 10:47 pm
I push dimensions all the time. It's a fun challenge and you can use more wood. Think it through first because some process or sequence might change.
PostPosted: Tue Jun 13, 2017 12:21 am
First name: Daniel
State: Washington
Thanks all. I have a KMG Mega mold - that will make it easy to test fit, and pull things in a little if needed. I'll use my Fox style bender so I can set the waist bend pretty accurately.
This one will be just for me, so I don't mind trying to push it a little. I've been building small bodies for others, but have wanted a dreadnought for myself for a while. This beeswing set looked perfect, but then I realized its also undersize by just a bit. I can get a full length back to fit, but the sides will demand a little more attention. I'll take it as a fun challenge.
Worth a try.
PostPosted: Tue Jun 13, 2017 5:50 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
30-1/32", based on our mold shape taken from a 1937 example, with just under 1/4" slop on each side at the tail block and ~3/8" each side at the heel...a 30" side works with just a tiny gap at the neck or tail, and our usually accuracy in alignment in the bender is about 1/16". The slack waist shape in both 12 and 14 fret dreadnought shapes (as well as the J-45 and AJ shapes) allows us to slipped about an 1/8" or more for waist location without issue, so it seems like 30" should be plenty of room if the bend is accurate.
- Beth Brower
These users thanked the author Woodie G for the post: dpetrzelka (Tue Jun 13, 2017 9:14 am)
PostPosted: Tue Jun 13, 2017 9:17 am
First name: Daniel
State: Washington
Woodie - thank you for taking tight measurements.
PostPosted: Mon Jun 19, 2017 9:41 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
My pattern is also 30 1/2". You can gain 1/8" at the butt (end wedge) and 7/16" at the neck heel, so it is possible. I have pushed the length a little, but not a full 1/2".
I bend by hand on a pipe. To line up the bend, I draw a line on the sides at the waist, and I have a corresponding line on the mold. I can usually get it within 1/16" without too much trouble.
These users thanked the author John Arnold for the post (total 2): dpetrzelka (Tue Jun 20, 2017 2:03 pm) • Clinchriver (Mon Jun 19, 2017 10:19 am)
PostPosted: Tue Jun 20, 2017 9:20 am
First name: Daniel
State: Washington
Thank you John - that's the pattern I'm working from, and if thats the case I may well be looking for an orphaned pair of bees wing mahogany sides to bring this one to life.
PostPosted: Tue Jun 20, 2017 1:43 pm
Just a thought, don't know if it would help - http://www.sobellguitars.com/news-page/page/7/
Near the bottom - Making a virtue of necessity
These users thanked the author Colin North for the post: dpetrzelka (Tue Jun 20, 2017 2:03 pm)
Users browsing this forum: Ken Lewis and 33 guests
